cancelar
Mostrando los resultados de
Quiere decir:
Switch Systems and Circuits: 3way switch in a system. Multi Sw Sys on Circuit.
Allow me to connect a switch to a circuit.  Then any lights (or outlets/fixtures) connected that switch would automatically be part of the same circuit.  Multiple switch systems should be allowed on one circuit.
A switch system should allow for 3 & 4 way switches.
The project I'm currently working on has a circuit with two "ALWAYS HOT" lights, a normal switch with one light attached and a pair of 3 way switches controlling several lights.  Which basically means that I need to show the wiring from the ALWAYS HOT fixtures to the regular switch then to one of the 3-way switches and then the home-run pointing to the Panel.
I need to graphically show a wire going from each 3-way switch to one of the lights and a wire going from the regular switch to the one light it has attached.
3 Comentarios
doni49
I meant to say that I was able to get my plan showing this by manually drawing the wires but it's definitely not BIM as there's no intelligence in the file indicating these connections.
jeanmarc.couffin
jeanmarc.couffin
Enviar idea
