Show only
Search instead for
Allow the Project Browser Organisation to be setup by user and not by file so that everyone can have their views showing according to their own preference and requirements for the ongoing task.
With the permission of one of the customers, I wanted to present an enhancement request for Revit. An idea came up to allow quick and easy sorting of views, sheets, schedules etc. in Project Browser by using drag and drop option. Additionally, the user wanted to create subcategories like a folders to which they could quickly move views containing a particular object. Currently, is possible can sort and group items by selected property and specify 6 levels of grouping. It is necessary to name views appropriately so that they can be found in the desired folder after the specified parameter.
In addition to the Browser Organization chosen overriding other's when syncing, if you have collapsed everything and then synced when others sync they will find their Project Browser all collapsed as well.
I'm hoping that the complete overhaul of the Project Browser that is being planned will take this into consideration as well!!!
Knock knock... just bringing this idea back to life! I still think this would be a great feature!
Scenario 1: In my team, some users prefer to organize the Project Browser by Sheet Types or Purpose, while others prefer a simpler setup — just sorting sheets by Sheet Number for quicker navigation.
Having a way to save and toggle between different browser organization presets (per user) would go a long way in improving flexibility, especially in larger teams with varied workflows.
Hola comunidad de revit! Saludos desde Argentina les habla el Arq. Max Borgogno les queria enviar un comentario para mejor comodidad del manej del panel de Project Browser, este panel se ajusta alfabeticamente con algunos problemas cuando el proyecto se vuelve masivo, algo para comodidad que se me ocurrio y queria sugerir es que el dibujo ya sea planta, corte, sheet pueda ser arrastrado, algo que hasta el momento no se permite, permitiendo la colocacion para mas comodidad
Hello Revit community! Greetings from Argentina, this is Architect Max Borgogno speaking. I wanted to send you a comment to improve the convenience of using the Project Browser panel. This panel adjusts alphabetically, with some problems when the project becomes massive. Something for convenience that occurred to me and I wanted to suggest is that the drawing, whether it be a floor plan, section, or sheet, can be dragged, something that is not currently allowed, allowing placement for more convenience.
Also, I believe a better idea would be to allow multiple sorting options in the Browser Organization set up, it could sort by level, and then type and then name or something like that. Between the multiple groupings and sortings, you would not have much of a list to go through if mostly collapsed and only the last grouping opened.
@jameshowellsLKN7T, please remember to do a search for existing ideas before posting a new idea. I searched "project browser user" and found it on the first page. I find that when searching for something using fewer words works better than more. Very generic words and "cave-man-speak" help too.
