multi-line text parameter formatting options
The possibility to add formatting like bold, underline, italics, note numbers/points... to the multi-line text parameter
1 Comment
wr.marshall
another handy feature would be to combine multiple values from other cells into one parameter, perhaps use " " to tell revit to use name of other parameter so if the value changes the multiline text is updated accordingly ie
"value 1"mm
"value 2"mm
"value 3"mm
Output
123mm
70mm
1000mm
