multi-line text parameter formatting options
The possibility to add formatting like bold, underline, italics, note numbers/points... to the multi-line text parameter
1 Comment
wr.marshall
another handy feature would be to combine multiple values from other cells into one parameter, perhaps use " " to tell revit to use name of other parameter so if the value changes the multiline text is updated accordingly ie
"value 1"mm
"value 2"mm
"value 3"mm
Output
123mm
70mm
1000mm
Forma Design Contest
Technology Administrators
