make ALL parameters schedule-able and filter-able
So often we are left with powerful data within the Revit model that is not schedule-able nor available in view filters. The data is there, but we cannot use it, in what are supposed to be core BIM functions like schedules and filters. Why is it that we can access those parameters and parameters values through the API or Dynamo, but that Revit itself cannot? Makes no sense. Open the data floodgates please!
30 Comments
mark.silcock
Scott_D_
This would be fantastic.
If it could allow embedded schedule parameters to interact and calculate with the parameters of the schedule they are embedded in, that would be even better.
harlan_brumm
Thanks for your submission and votes on this idea!  We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision.
The Factory
jan
Thank you for putting this under review.
If the task looks daunting, there's an almost-perfect standard out there of what Revit scheduling should look like: it's called Ideate BIMLink.
lionel.kai
Should include a "Titleblock" Field for Sheet Lists.
GPnmulder
Schedule-able, filter-able, and tag-able!
Ricard_S
@harlan_brumm: How did the evaluation go? 🙂 *Curious*
Scott_D_
They are probably thinking that it is time-consuming but not particularly difficult unless they also change the system parameters we want to use for numeric calculations that are text to be the correct type of parameter which would probably be a headache, but obviously very much appreciated. Smiley Very Happy
lionel.kai
@Scott_D_ That's exactly why we need text-handling/conversion functions (see Allow text in formulas [UNDER REVIEW] and Concatenation Of Parameters Within Families).
Scott_D_
Thanks for the links, I have voted for both.
gabriel_vilela
Would be very useful, especially to filter with workset, for example.
zhuliyi0
Take a look at this new tool on Revit Store:
123 Search
It solves this problem and many more.
pieter4
I would like to see the parameter 'room bounding' be available in view filters so we can create a view template that shows room bounding elements. It would help with tracking room issues.
aaronrumple
Just build them all in as BuiltIn parameters... Too many shared parameters, too little time.
lionel.kai
@aaronrumple What do you mean? The problem is BuiltIn parameters that aren't schedulable (copying them to Shared Parameters is the workaround).
brunelli.b
Adding to this, all built-in parameters should be made available in the Family Editor, so that they can be used to calculate parameter values based on a built-in instance parameter. I'd specifically like to access the "Elevation from Level" parameter in the family editor, but it would also be useful for others as well.
SBRANCH2PCN5
Curty102
@GPnmulder Yes, it would be great if there was a Tag family that, when loaded, could tag ANY family and, upon tagging, the user could select which Parameter(s) in the family to report.
Curty102
@jan  Another workflow could be to make pushing shared parameters into families easier, perhaps a mapping dialogue that allows the user to specify which Parameter in each family is being mapped/replaced.
Curty102
@jan  Yet another workflow may be to add a Parameter mapping dialogue in the schedule itself, allowing mapping of parameters for each family type to a Parameter in the schedule.
