Along with the combo box dropdown lists within the family editor suggestion that has already been made, it would be really useful if we had the ability to concatenate parameters to fill in other parameters such as description or material specification d also need the ability to add common text elemets in "" to make the concatenated field read correctly.
Example
We have the following parameters in a flashing family, Flashing Girth, Flashing thickness, Material, Colour. To fill out the description we would put the formula =Flashing Girth & "GIRTH, &" Flashing thickness & "THICK " & "Material & "FLASHING, COLOUR" & Colour
would produce = 250mm GIRTH, 0.7mm THICK HPS200 PRE-COATED STEEL FLASHING, COLOUR MOONSTONE RAL 7035
Darren
