Increased API Functionality for Sections
Sections in the API need a bit more love
There is basic functionality missing that should just be there.
The biggest thing missing is the Location property.
To Get and Set the property is essential when you just can't delete and create new.
Also these three basic functionality:
  • Check if section is flipped, and flip it through the API
  • Get and Set the section heads individually at each end.
  • Create gaps and remove gaps
Basically, just have access to the same buttons and controls we see in the UI:
Related topics:
Revit API - Adjust Section Line - Autodesk Community
API split section location - Autodesk Community
Solved: How can I get the coordinates of the endpoints for a section marker line segment - Autodesk ...
Split section - Autodesk Community
Split segment of a view section via API - Autodesk Community
