Dimension Arrow placement
Dimensions in Revit should include the ability to flip the arrowheads on Linear or Aligned dimension to display outside of the witness lines.  This will allow the dimension text to placed inside (between) the witness lines, while still adhering to ASME Y14.5 drafting standards and keeping the drawings legible and professional looking.  Currently, if the dimension text is moved to display between the witness lines, and the text background is set to Opaque, the arrow heads are often completely or partially hidden.
This topic was brought up on 05-19-2016 at 05:59 pm by a.bryant and was subsequently dismissed.  This topic should be activated and resolved.
9 Comments
ac_bryant
Include a function to force dimesion arrowheads to the outside (flipped dimension lines).
Currently it only does it when the arrowheads are close together, but sometimes you need to force them to the outside.
Tags (2)
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
tim.perkinsSHINE
Just posted the same request titled Dimension Arrow placement.  This is an on-going issue that AutoDesk told me is by design.
New post is at https://forums.autodesk.com/t5/revit-ideas/dimension-arrow-placement/idi-p/10745682
wr.marshall
related: Angle Dims, Linear Dims, Radius Dims... are controlled by one common Family Type - Autodesk Communit...
@tim.perkinsSHINE please provide link to the other persons idea as I can't seem to fine
tim.perkinsSHINE
wr.marshall, the topic was call Dimension Arrowhead Flip.  Below is the link.
https://forums.autodesk.com/t5/revit-ideas/dimension-arrowhead-flip/idi-p/6339237
wr.marshall
@kimberly_fuhrman-jones Please un-archive @tim.perkinsSHINE link and combine
Please note my link is related but something different.
@tim.perkinsSHINE Thank you for link
@wr.marshall ,
Thank you! Typically we keep archived Ideas archived, but I did combine @tim.perkinsSHINE link with this one.
-Kimberly
wr.marshall
