Angle Dims, Linear Dims, Radius Dims... are controlled by one common Family Type
currently each of these are seen as a separate type of Dim, requiring you to setup the style for each, duplicating the style for other dim types so that they look similar. ie set linear to use TEXT-FONT with size of X, then repeat process for Angle Dims, repeat for Radius Dims. If had a common family editor for the dims it would control the style for all dim types to be used or are used.
1 Comment
wr.marshall
