Side by side configuration - sxstrace.exe
i have hp 64bit lp with win10 all vc++ installed perfectly and i had installed cad and 3ds both working fine but revit it is not opening says side by side config incorrect i tried all solutions available on internet but nothing work like reinstalling c++ and windows update but nothing work so please give me correct solution
thank you
TravisNave
If you have exhausted this:
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/The-ap...
Then you might try installing the Universal C Runtime for Windows 10 from Microsoft.
https://www.microsoft.com/en-us/download/details.aspx?id=48234
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
