Revit license
Revit license
rosanes.angel_martin
Revit license
Dear all
I'm waiting to new Revit license and my question is:  it's possible install the "Free 30-day trial " and when I have the license code put it in this installation?
best regards
ennujozlagam
hello, yes you can use trial version first for 30 days until you receive your license code and key-in when license code receive. thanks
TravisNave
Yes, this is allowed.  Keep in mind that you can only run it as a trial for one 30-day period and that it cannot be reset.  So you should be able to get your license before that time is up.  Good Luck!
Autodesk Forums:
FYI...if you have a network license, you will have to uninstall and reinstall Revit, as during the setup is the only time you can select Network vs Standalone.
TravisNave
True.  They broke Revit switching in 2012.  But it looks like license switching is back for 2017!  Woo!
Autodesk Forums:
