A stair with different Steps
18 REPLIES 18
Message 1 of 19
TomasoCardia
2069 Views, 18 Replies
Hi all!
I'm tring to build this type of stair (image 01,02).
Is there a way to build it as one stair (with different steps)? How ?
18 REPLIES 18
Message 2 of 19
in reply to: TomasoCardia
Paint tool? Looks like you just want to change the tread surface material.
Message 3 of 19
TomasoCardia
in reply to: barthbradley
on the second image are two different steps
Message 4 of 19
Looks like two different stair types then. Do it that way; one stair type without stringers on top of another stair type with stringers.  No?
Message 5 of 19
loboarch
You will never get it with one stair. Looks like 2 stair types to me. 1 "regular" stair and one that is deep like seats.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 6 of 19
TomasoCardia
in reply to: loboarch
going ahead to this way, altough I think is it incredible that there is not other way to do this real common stair..
Thank you for your helps
Message 7 of 19
Below is what I would do.  A big stair and smaller steps as pieces of floor.
Message 8 of 19
If Section "Corte A-A" is accurate, I would say that this stair design is not "common".   Just saying.  I think doing it as two stairs is closer to the way it will get constructed in the field.
...actually, I take that back. I like @ToanDN's approach. That's how I'd roll....or "step". Nice job though, @TomasoCardia
Message 9 of 19
Message 10 of 19
TomasoCardia
in reply to: ToanDN
ok 🙂 How did you built it?
Message 11 of 19
in reply to: ToanDN
...reminds me of head-rolling day.   Smiley Wink
Message 12 of 19
See my post above it. I was trying to add the final image to it but wasn't allowed so I had to create a new reply.
Message 13 of 19
Corsten.Au
Split Stairs in 3 parts..Split Stairs in 3 parts..
All the risers should touch two Boundaries, that constraints the way stairs are modelled..
check this if that helps..
https://www.dropbox.com/sh/xviskk5nvjuiv9c/AAAwSn7cbPLtFLF3-wMpv8iAa?dl=0
Corsten
Building Designer
Message 14 of 19
TomasoCardia
in reply to: ToanDN
The problem in this solution is that if you want to measure the right m3 of concrete you need, for example, you cannot (or you can do it but not the in the right way - the construction system are different)
Message 15 of 19
TomasoCardia
in reply to: Corsten.Au
Really brilliant solution!
Thank you very much
Message 16 of 19
TomasoCardia
Done!
Thank you to all!
Message 17 of 19
Thank you! but I can't download the attachment, could you explain how to build it?
Message 18 of 19
in reply to: ToanDN
Hi ! How to build it? Thank you!
Message 19 of 19
Start a new tread @Anonymous .
Forma Design Contest
Technology Administrators
