A stair with different Steps
TomasoCardia
TomasoCardia
Hi all!
I'm tring to build this type of stair (image 01,02).
Is there a way to build it as one stair (with different steps)? How ?
Replies (18)
Paint tool? Looks like you just want to change the tread surface material.
TomasoCardia
on the second image are two different steps
Looks like two different stair types then. Do it that way; one stair type without stringers on top of another stair type with stringers.  No?
loboarch
You will never get it with one stair. Looks like 2 stair types to me. 1 "regular" stair and one that is deep like seats.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
TomasoCardia
going ahead to this way, altough I think is it incredible that there is not other way to do this real common stair..
Thank you for your helps
Below is what I would do.  A big stair and smaller steps as pieces of floor.
If Section "Corte A-A" is accurate, I would say that this stair design is not "common".   Just saying.  I think doing it as two stairs is closer to the way it will get constructed in the field.
...actually, I take that back. I like @ToanDN's approach. That's how I'd roll....or "step". Nice job though, @TomasoCardia
TomasoCardia
ok 🙂 How did you built it?
...reminds me of head-rolling day.   Smiley Wink
See my post above it. I was trying to add the final image to it but wasn't allowed so I had to create a new reply.
Corsten.Au
Split Stairs in 3 parts..Split Stairs in 3 parts..
All the risers should touch two Boundaries, that constraints the way stairs are modelled..
check this if that helps..
https://www.dropbox.com/sh/xviskk5nvjuiv9c/AAAwSn7cbPLtFLF3-wMpv8iAa?dl=0
Corsten
Building Designer
TomasoCardia
The problem in this solution is that if you want to measure the right m3 of concrete you need, for example, you cannot (or you can do it but not the in the right way - the construction system are different)
TomasoCardia
Really brilliant solution!
Thank you very much
TomasoCardia
Done!
Thank you to all!
Thank you! but I can't download the attachment, could you explain how to build it?
Hi ! How to build it? Thank you!
Start a new tread @Anonymous .
