Hi @wobrien, @isaac_hedberg, and @ArmandD
I've been discussing this issue with our Revit domain expert and he suggested the below:
- Please create a backup of your Revit ini (move to desktop)
- Backups Settings in Revit.ini
In the Revit.ini file, the settings in the [Backups] section correspond to settings on the General tab of the Options dialog.
- Rename existing Revit.ini to old
- Then launch Revit and see if there is a difference in the recent project list
- Send me the results or let me know if the same issue persists.
Meanwhile, each of you should have received the upload folder link by now. I shared a readme.txt and a collector utility folder to extract your individual data-sets.
Please note that any information you've shared is private and will be deleted once the issue is resolved.
Also, take time to read this article: Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Let me know when you've uploaded and if you have trouble accessing the folders. Unless I have the data-set I'll be unable to move forward with the investigation.
Thanks and looking forward to hearing from each of you!
