2019.1 Recent Files list not updating correctly
isaac_hedberg
Message 1 of 117
isaac_hedberg
We have multiple computers running Revit 2019.1, where the recent files list (both home screen and file menu) are not updating the projects after applying the patch.  It worked great on 2019 prior to the .1 patch.  We don't use worksets on our projects, so this is not a central file vs. local file issue.
Any ideas for fixes are appreciated!
Ike
Title edited for clarity by @Viveka_CD
Replies (116)
Message 101 of 117
Darin_HDR
I had fixed this issue but it popped back up with the recent Hotfix update (2019.2.1).
Message 102 of 117
Nurlan-A.
I have the same problem,
Revit 2019.2.1
Message 103 of 117
Mark_Engwirda
The best way is to ignore "recent files" completely and open the files directly from where they are stored.
This way you know you are reliably opening  the correct version of your file.
The "recent files" in Revit has never worked correctly since it's inception so I guess they are not too worried about fixing it.
Message 104 of 117
Nurlan-A.
Solution Recent-files-list-and-Recent-File-icons-are-updating-in-Revit
In short: open Revit.ini, find & empty Recent File List, save.
Message 105 of 117
Mark_Engwirda
Rather than going to the ini file, Autodesk should find a permanent robust
solution. That would be easier for everybody 😉
Message 106 of 117
RobDraw
They fixed it...
Rob
Message 107 of 117
kdorbert
Same issue here right now. Revit 2019.2.1
I didn't read through the whole thread, what's the latest solution?
Message 108 of 117
RobDraw
You don't have to read the entire thread. Just start from the end and go backwards.
Rob
Message 109 of 117
Viveka_CD
Hi @kdorbert
If the recommendations/ solutions in this thread does not help with your issue, then please log a case with support
A specialist should be in touch with you!
Message 110 of 117
Nurlan-A.
OP or Mods should mark the answer to save time
Message 111 of 117
isaac_hedberg
As the OP, I just accepted the only solution there has been so far... which is to edit the .ini file.
I've moved on to 2020 and no longer care if they fix 2019.X  Hopefully the issue doesn't persist in the latest version, but if it does we'll start again.
Message 112 of 117
kdorbert
Thank you. We're not on 2020 yet, so this will continue to suck, I guess.
Message 113 of 117
I just submitted a support request on this issue, as I am on the latest greatest build of 2019:
(19.2.10.7  -  20190225_1515(x64)  -  2019.2.1)
and I'm still having the same recent files screen problem, but with wildly random variations.
It just is not acceptable for Autodesk to tell us the solution is to use to Revit 2020, knowing that with its lack of backward compatibility, firms like ours who collaborate with other companies cannot be in the driver's seat on when to move to the latest version.  (Sometimes we also have delays in getting access to the latest version from our enterprise contract.)
When I get a response, I will share it here.
  -- Haden D. Smith, AIA, Ross & Baruzzini, St. Louis, MO
Message 114 of 117
Viveka_CD
Hi @Anonymous
Thanks for your report. A specialist will be looking into your issue.
I understand your frustration and will try best to assist.
Meanwhile, can you please let me know if it is the recent files (in the File menu) or the Revit Home page that does not sort the models as expected? Please attach some screenshots.
Related article: link
Message 115 of 117
@Viveka_CD
Then that's a very poor decision. When I open Revit, 99% of the time, I want to open the last shared model I worked in.
What you've done is the opposite of streamlined and ease of navigation. I now have to browse for my project every time, rather than clicking the project tile when I launch Revit.
Message 116 of 117
RobDraw
She didn't do anything but try to help.
Please see message #109.
Good luck.
Rob
Message 117 of 117
Viveka_CD
Hi @RobDraw
Please check this article:
Recent files list and Recent File icons are not updating in Revit
We can assist better if you contact us through our support portal with datasets
https://knowledge.autodesk.com/contact-support
I don't monitor the forums as closely as before, but I'll be glad to forward your specific issue to other specialists.
Thanks!
