Upgrading to 2017 Revit
2 ANTWORTEN 2
Nachricht 1 von 3
jsloan.draw
418 Aufrufe, 2 Antworten
I am going to upgrade to Revit 2017 through subscription.  I currently have Revit 2014.   If I download the new version will it replace my old version?  I would like to keep my old version until I have a couple projects finished and I have made the full change to 2017.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: jsloan.draw
You can install separate versions of Revit so it will not replace your copy of 2014. You could install 2015, 2016, 2017 and they will all function separately.
Nachricht 3 von 3
Clarke_Symetri
It will not replace your old version, it is a completely separate install / program.
With subscription, you have access to the current software, plus the 3 previous releases (2014-2016-2016). Hope that helps.
Clarke Morrison | Solutions Specialist - Architecture
Revit 2015 Certified Professional
Autodesk Authorized Instructor
MICRODESK, INC.
51 Franklin Street
Boston, MA 02112
main: 800.336.3375
www.microdesk.com
