Revit.ini error message & Reset
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
660 Aufrufe, 3 Antworten
We have a bout 25 stations with Revit on network licenses.
When we update the Revit rescources (material path, save path, etc), we often get the error "Error Saving options. Please ensure that Revit.ini is not read only." However, the Revit.ini is not read only.
On a random interval, our settings go back to the defaults. For me it's every months or so, for some users it's every session.
Any clues on how to solve this?
3 ANTWORTEN 3
Nachricht 2 von 4
Richard.P.Garcia
als Antwort auf: Anonymous
Hi @Anonymous,
I have seen cases like this which is caused by addins, try removing some recently added plugins. In some cases, Enscape plugin causes it.
Hope this helps.
Please hit the "Accept as Solution" button if my post resolves your issue and give "Kudo" as appropriate.
Richard P. Garcia
Technical Support Specialist
Nachricht 3 von 4
als Antwort auf: Richard.P.Garcia
Updating the Enscape Plugin to the latest version did the trick!!
Thanks a lot! This was a very obscure and annoying problem.
Nachricht 4 von 4
Richard.P.Garcia
Hi @Anonymous, you're welcome. Glad to be of help.
Richard P. Garcia
