2019.1 Recent Files list not updating correctly
isaac_hedberg
Message 1 of 117
isaac_hedberg
We have multiple computers running Revit 2019.1, where the recent files list (both home screen and file menu) are not updating the projects after applying the patch.  It worked great on 2019 prior to the .1 patch.  We don't use worksets on our projects, so this is not a central file vs. local file issue.
Any ideas for fixes are appreciated!
Ike
Title edited for clarity by @Viveka_CD
Replies (116)
Message 41 of 117
I'm having the same issue, recently opened files not showing up on the homepage, and so far none of the solutions here help me either. Is anybody on the development team looking into this issue?
Message 42 of 117
Viveka_CD
Hi @Anonymous
Yes we have development looking into this issue.
Let us know if this happens on local models, or workshared models.
We will require a date set from you end for further diagnosis. See Revit - Collecting and sending diagnostic data to Autodesk Technical Support
It will be great if you can send us some screenshots and a screencast like @ArmandD
This will help in further diagnosis.
Message 43 of 117
This happens on both file types, all files saved locally on my machine. Here are the steps:
1.  Open file
2. Make changes and save and close
3. The file does not show up in my recent files
Screencast link is included.
Message 44 of 117
wobrien
Just chiming in. I have been trying to keep an eye on every thing that I do to see what causes the bug and haven't found any solid reason yet. At first I thought it was renaming a file and therefore its entry on the landing page was removed. This would cause one of the default sample projects to take the last spot on the list. Sometimes this would trigger the list not updating but other times it wouldn't. I have been "cleaning" my revit.ini file when the list stops updating and starting from scratch to get things working again (albeit with no previous file history). Another behavior I have noted is some entries will just vanish from the "recents" landing page while they still show up in the revit.ini. Those pesky three default sample projects of course make their way back on the landing page. My workday usually consists of hopping between 10 or so projects (and their nested projects) so I can easily load up the recents lists with "new" entries.  Oddly enough sometimes when I open Revit, the Recent Files landing page is down to four or so projects in addition to the three defaults. I hope ANY of this information I have provided helps to uncover the issue as having a broken file history list is obnoxious when bouncing between multiple projects a day.
Message 45 of 117
ArmandD
I saved a file with no abnormal characters or spaces in the name to my desktop. Same issue. Still did not show up on the 'Home Page'.
Message 46 of 117
Viveka_CD
dHi @ArmandD@isaac_hedberg@wobrien
Thanks for all the information, you've provided so far!
This issue is under investigation - and is in progress by the Revit home resource team.
We also want to know the below:
1) How many files are Revit models?
2) How may are Revit families and Revit templates?
3) Are there any older version models in the recent list.
4) do you use drag-drop or double-click directly?
Additionally, can you share the 12 files so that we can recreate your issue individually? You can upload to the same folder I've previously shared with you!
Appreciate your patience while this issue is in progress, and thanks!
Looking forward to hearing from you.
Message 47 of 117
ArmandD
Viveka, it seems that I don't have the upload option in the folder with my name anymore.
Message 48 of 117
Viveka_CD
@ArmandD I've changed the permissions, please try accessing the folder now and let me know!
Thanks!
Message 49 of 117
isaac_hedberg
Hi @Viveka_CD
#1 & #2 are broken out in separate categories on my home screen and the answer for my recent files list changes multiple times a day.  The models section only shows the most recent 10 models.  Based on the extensions in the Revit.ini file I sent though: 12 are models, 2 are templates, and 1 is a family in the recent files list.
3.  Yes, if I were to guess 9 of the files were upgraded to 2019 at one point, probably 4 of those were a save as of the upgraded file rather than upgraded themselves.
4.  I assume this question is about opening files.  I either single-click on the home screen file or browse through the open menu to open projects.
Message 50 of 117
Viveka_CD
Hi @isaac_hedberg
Thanks for the information and details!
I am not seeing your data-set in the shared folder. Can you please upload again or I can send you an alternate uplaod link.
Message 51 of 117
wobrien
Sorry, dealing with quite a few pressing deadlines at the moment. When I catch a break in my schedule I will be sure to upload a new user data dump.
Message 52 of 117
Viveka_CD
Thanks @wobrien
I will look forward to your files.
Message 53 of 117
Viveka_CD
1.  Open file
Hi @Anonymous
Just checking back on your issue. We will re-create the issue based on your data-set, can you send across your files (recent files) and diagnostic data?
Also let us know if these are default families, sample files or default template files and upgraded files.
Message 54 of 117
These are not default families or sample families. Templates never show in the recent files so that's not an issue. Some of the files are upgraded, but some of the upgraded files are already showing in the recent list, not sure why that would matter since it worked before. Are you asking me for my Revit files? I can send you a link to them in my A360 account but I won't post them here publicly. And to what diagnostic data are you referring?
Message 55 of 117
Viveka_CD
@Anonymous
Thanks for responding!
Please look forward to a private folder link.
Message 56 of 117
Viveka_CD
@Anonymous
I've shared a link with you, Let me know if you have trouble accessing the files.
Message 57 of 117
wobrien
I got a chance to finally upload some more user data dumps. I have been problem free (a week or so) ever since I cleaned out the revit.ini [Recent File List] section until today. I have been working in single user Revit projects (non-central) until this morning when I hopped into a work-shared project. Now the list is refusing to update again and the three default projects are back on the list (at the end of the full 10 project entries). I also happened to unload a *.rvt link within that project, made edits, saved, then reloaded it back in once done.
So, the trigger for me is either a central model or unloading and editing a linked file. I would also like to note that I opened the central model directly (not a local user file of the central) from the windows file explorer and saved my changes (this file was not on the recent list in Revit). I'll upload this latest user data dump marked with today's date. This central project file has been upgraded through multiple version or Revit all the way from 2015 and wasn't made a central model until Revit 2016. Again, I hope any of this helps otherwise cleaning the revit.ini is working for our office in the meantime.
Message 58 of 117
wobrien
I no longer have write access to the shared 360 folder. If I could get that changed I will upload those user data files. Thanks.
Message 59 of 117
Viveka_CD
Message 60 of 117
Viveka_CD
@wobrien@isaac_hedberg, @Anonymous, @ArmandD
A quick update on this issue.
Development is looking into this issue now defined as Revit home bug. This incident is being investigated for a possible cause and resolution.
Please keep an eye on this article for more workarounds and updates: Recent files list and Recent File icons are updating in Revit
