Problem installing
Problem installing
Problem installing
I m having trouble installing maya...my laptop passes all requirements but when the install is completed a message is diplayed saying maya failed to install....i have a project tomorrow....can you do anything?
TravisNave
You need to post your installation log file so we can see why it is failing.  Without that log I can only guess.
In the mean-time, I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
