Next assembly list
Next assembly list
Message 1 of 15
Next assembly list
All,
We have a title block that lists the "NEXT ASSY" which is the next assembly where a particular weldment, piece part or subassembly would reside. Currently this is a manual input which is often missed or incorrectly inputted by designers/engineers. Does anyone know of illogic code that would capture this Vault information in the .idw environment and self populate this field??
Any help is greatly appreciated!
Shawn
Replies (14)
Message 2 of 15
bradeneuropeArthur
You mean where used?
where the assembly in the drawing is used in the other assembly?
This is definitely possible with the vault API.
But:
What if the assembly is more times used in another assembly.
If the above situation is correct than I can provide you the code for an add in but not for I-logic.
I think it is hardly not possible with I-logic.
So my advise is start programming your own add in for this.
Please let me know about it.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 15
Thanks for you reply. Yes where used. If it happens to be used else where then that would be listed also. See sample attachment. So we would know all the projects and upper level assemblies it is used. This is very helpful information on our drawings to let the assemblers and receiving dept easily find where these get installed. A code for an add in would be great if you can point me in that direction.
Thanks in advance!
Message 4 of 15
bradeneuropeArthur
I will gilde you asap.
Maybe tommorow!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 15
bradeneuropeArthur
Guide...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 15
ok. thank you very much!
Message 7 of 15
MechMachineMan
This thread also has an alternate solution that sounds very close to what you want:
https://forums.autodesk.com/t5/inventor-customization/part-quantities-per-assembly/m-p/6858321/highl...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 8 of 15
bradeneuropeArthur
Sorry I will take a look next week ASAP.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 15
Ok thank you!
Message 10 of 15
bradeneuropeArthur
I hope you are using vault 2018!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 15
bradeneuropeArthur
Otherwise I don't have the api available for other versions of vault.
And what version of vault are you using?
Basic
Pro
Workgroup
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 15
bradeneuropeArthur
Can you please send me a private message otherwise I will forget. Put please the link in there to this topic.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 15
I am using Vault 2018 Workgroup.
Message 14 of 15
bradeneuropeArthur
Sorry very busy at the moment.
I will take a look asap.
I am using vault pro.
This is different I need to investigate
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 15
ok. Thank you!
