release refernced dll from iLogic
omartin
omartin
I created a helloWorld dll with one sub that excepts an inventor document.
and display the filename with msgbox
in an I logic rule I ref the dll and make an object, and call the sub.
That works fine, however; if I try to make changes to the dll it cant compile because it is in use. I have to restart inventor
Is there a way to unload/release the dll from being used after the rule has finished running?
Was my reply Helpful ? send a Kudos or accept as solution
JamieVJohnson2
This behavior is common throughout most programs that load dlls.  They stay persistent until the main thread closes.  The only system I know that has a work around is the 'Edit and Continue' methods of Visual Studio.  So there has to be a way, but even then some changes can not continue without reloading.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
omartin
Hey GeorgK this seems like it will work I'm trying to convert it to VB and getting hung up on the MarshalByRefType portion
I will keep trying, thanks
