iLogic: Fill in iProperty of parts and sub asssemblies, except "Purchased" Parts
Hello everyone,
I’m trying to create an iLogic routine that fills in the project number in the main assembly and all parts and sub asssemblies, except when a part or assembly is a “Purchased” part.
I have a rule now but it only adds the project number to the 1st layer of parts and subassemblies.
I have no clue how to have this rule fill in de project number in sub-sub assemblies and parts in sub-sub assemblies, etc. Until all levels are checked and filled in.
I hope you can really help me out. I checked several blogs on the Mod the Machine blog, but it seems that the code used there is nog working anymore in Inventor 2017.
The code I have is :
'Fill in project number
pProject = InputBox("Projectnummer", "Projectnummer")
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
' Get the assembly component definition.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
' Iterate through all of the Part Occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
' Set Reference to Occurrence Name
Dim oOccName As String
oOccName = oOccurrence.Name
If oOccurrence.Definition.BOMStructure = 51970 'Normal
iProperties.Value(oAsmDoc,"Project", "Project") = pProject
iProperties.Value(oOccName,"Project", "Project") = pProject
If oOccurrence.Definition.BOMStructure = 51971 'Phantom
If oOccurrence.Definition.BOMStructure = 51972 'Reference
If oOccurrence.Definition.BOMStructure = 51974 'Inseparable
Next
Thanks a lot for taking time to read my question!
Best Regards,
Sjaak
MechMachineMan
The blog you are looking for:
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
The easiest working code:
For Each oSubDoc in oAsmDoc.AllReferencedDocuments
If oSubDoc.IsModifiable = False Then: Continue For: End If
If oSubDoc.ComponentDefinition.BOMStructure <> BOMStructureEnum.kPurchasedBOMStructure
oSubDoc.PropertySets("Design Tracking Properties")("Project").Value = pProject
End if
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Hello MechMachine,
Thanks a lot for your quick reply!  This is the exact information I was looking for.
I had to rebuild the code a little because I got an error in  these lines:
And the project number wasn't added tot the main assembly itself so I added an extra line of code at the end as well. The complete code now looks like this and works perfect:
Next
