Some how moved my XZ plane off of the origin how to I reset it?
So I was working off one of the origin planes and somehow managed to move it? all my old sketches and extrusions are centered at the origin but now any new sketches look like this? Generally I would just control Z back a little and that would fix it but not this time. anyone have any ideas?
MechMachineMan
No ideas without seeing the file.
Also, this post is better suited for Inventor General Discussion as it has nothing to do with the API nor iLogic.
I'll ask for it to be moved.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks for your reply unfortunately there doesn't seem to be a "General" under Inventor its either "Customization" "Engineer-to-order" or " Publisher"
I was just hoping there was a "reset origin planes" or some such option.
MechMachineMan
It's just the top option - "Forum".
I don't think there is any such command as that in the Part file.
And if we can see the part file, we can likely figure out how it happened and how to prevent it in the future.
Justin K
