Add user text parameter through iLogic
Using Inventor 16
I am trying to add a user text parameter to the active document (typically ipt) with the following in an iLogic rule:
oUParams=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oUParams.AddByValue ("Description","",UnitsTypeEnum.kTextUnits)
Running this doesn't throw any errors, but it also doesn't create the parameter.
What am I doing wrong?
MechMachineMan
Works fine for me.
Please ensure that you don't have any filters applied in your parameters dialog.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
gavin.allenHSSRX
This does not work for me either.  Is there some coding before or after we should be using?
K.I.S.S. (keep it simple stupid)
Life doesn't have to be complicated.
Designs don't have to be complicated.
GOD Bless you.
MechMachineMan
I tried it again, and copy/pasting that code adds the parameter just fine.
Perhaps it wouldn't if the part wasn't a library file, or unmodifiable otherwise?
Try adding the user parameter manually through the UI. Does that work?
Secondly, can you verify that you don't have an parameter filters on?
Thirdly, you are running the parameter from the ACTIVE document and not during an "in-place edit"?
If you want it to work even during in-place editting, it should be written:
oUParams=ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
Justin K
bradeneuropeArthur
This works for me:
    Private Sub Button25_Click(sender As Object, e As EventArgs) Handles Button25.Click
        Dim oDoc As Document
        oDoc = _InvApp.ActiveDocument
        'On Error GoTo noPartOrAss:
        Dim oParameters As Parameters
        oParameters = oDoc.ComponentDefinition.Parameters
        Dim oParameterTables As ParameterTables
        oParameterTables = oParameters.ParameterTables
        'Debug.Print oParameters.ParameterTables.Count
        Dim oParameterTable As ParameterTable
        oParameterTable = oParameterTables.Item(1)
        Dim oUserParameters As UserParameters
        oUserParameters = oParameters.UserParameters
        Dim oTableParameters As TableParameters
        oTableParameters = oParameterTable.TableParameters
        Dim UserParameterAdd As UserParameter
        UserParameterAdd = oUserParameters.AddByValue("Test" & "_UPT", "AA", UnitsTypeEnum.kTextUnits)
    End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
gavin.allenHSSRX
Bless You Justin,
I was trying to do it thru the in place edit.  Thanks so much for the edification.
GOD Bless you.
MechMachineMan
If that has it solved, please mark the answer as a solution!
Justin K
