Inventor iLogic save as
mjplaatwerk
mjplaatwerk
Hi there,
Is it possible to save and replace a part from an assembly in iLogic?
Thanks for your help.
Marcius Janssen
Thomas_Savage
Yes you will be able to do this.
Could you attach your model please?
Thomas.
Thomas Savage
Design Engineer
mjplaatwerk
This is the case.
I've got an assembly (Box-parametric.iam) of a box (Box-parametric.ipt) with
a lid (Lid-parametric.ipt).
With the help of a form in ilogic I can change the dimensions of the box and
the lid within the assembly.
Now I want to "save as" the partfile of the box with a filename that
consists of the word "Box" followed by the dimensions of the box.
I've figured out how to make the correct new filename but I don't know how
to "save as" a partfile from the assembly.
The same goes for the lid.
After the "save as" I want to replace the box (parametric) with the box with
the dimensions in the filename and the same for the lid.
At last I want to "save as" the assembly with the filename followed by the
dimensions.
MechMachineMan
It really depends on how the rest of your script is coded to understand the best way forward.
ONE possible way is as below:
'To Save an occurrence:
oSaveName = "C:\PartTest.ipt"
Dim compOcc = Component.InventorComponent("430-1986:1")
compOcc.Definition.Document.SaveAs(oSaveName, True)
'To Save the top level:
oFileNameHere = "C:\ASMTest.iam"
ThisDoc.Document.SaveAs(oFileNameHere, True)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
mjplaatwerk
Deur Justin,
I've been to busy to try your solution.
As soon as I find the time to proceed I will let you know if it works.
Greetings,
Marcius Janssen
