Good day,
I'm going to add extra structural shapes in Inventor for work.
As a test I started with a simple iPart, created a square tube with parameters length, width, height and thickness.
After that I added about 50 different profiles in excel, published the shape with the structural shape publisher.
Then I created an assembly using a configuration of the new family I added, even that works perfectly.
Where I bumb into a problem is the part list. In the column length, the part list shows the height of the profile, instead of the length.
See screencast for reference, it should show 2x 500mm and 2x 200mm but shows 2x 20mm, 1x 20mm and 1x 20mm for some reason.
I hope someone can fix this for me.
Thanks in advance.
Sjors
