Adding content center structural shapes - Bill of materials
Message 1 of 42
Good day,
I'm going to add extra structural shapes in Inventor for work.
As a test I started with a simple iPart, created a square tube with parameters length, width, height and thickness.
After that I added about 50 different profiles in excel, published the shape with the structural shape publisher.
Then I created an assembly using a configuration of the new family I added, even that works perfectly.
Where I bumb into a problem is the part list. In the column length, the part list shows the height of the profile, instead of the length.
See screencast for reference, it should show 2x 500mm and 2x 200mm but shows 2x 20mm, 1x 20mm and 1x 20mm for some reason.
I hope someone can fix this for me.
Thanks in advance.
Sjors
Replies (41)
Message 41 of 42
Thanks for the help.
Feel free to be more kind in the future.
Message 42 of 42
bradeneuropeArthur
Who has solved and bring the effort?
What went wrong here!!!
Think you must have made a mistake here!!!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
