Exporting as PDF slow
I recently updated my drawing template and did the following,
Change my Font to Gulin
Add a JPEG to the drawing - 60kb
Since i updated these, my export has been slowed drastically, any idea on how i can improve this?
bradeneuropeArthur
Try the same without the jpeg in the drawing.
and test both.
if you see difference than this is the issue.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
To reproduce slowness, could you please provide drawing template which contains image?
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
