Adding content center structural shapes - Bill of materials
Message 1 of 42
Good day,
I'm going to add extra structural shapes in Inventor for work.
As a test I started with a simple iPart, created a square tube with parameters length, width, height and thickness.
After that I added about 50 different profiles in excel, published the shape with the structural shape publisher.
Then I created an assembly using a configuration of the new family I added, even that works perfectly.
Where I bumb into a problem is the part list. In the column length, the part list shows the height of the profile, instead of the length.
See screencast for reference, it should show 2x 500mm and 2x 200mm but shows 2x 20mm, 1x 20mm and 1x 20mm for some reason.
I hope someone can fix this for me.
Thanks in advance.
Sjors
Replies (41)
Message 21 of 42
bradeneuropeArthur
See the picture below:
Go to manage project
select Content Center Button
check the Content Center You are using.
Export this to Desktop CC
and upload the idcl file that has been exported.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 22 of 42
Alright thanks, never done this in years.
See attached file.
Message 23 of 42
bradeneuropeArthur
I have investigated the issue.
The tables are not formatted correctly on all fronts!
Seems that the I-parts are uploaded very simple without doing anything to handle it in Content Center.
Please become familiar with Content Center and behavior and settings before doing anything in Content Center!
The first things I saw and need to be changed are:
Member Column:
Part Number Column:
File name Column:
I will investigate further because the parameter mapping is also not done correctly, and is also related to the issue.
Width height and Thickness:
Do the following for the parameters Width height and Thickness:
Afterwards it works.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 24 of 42
Hi branden,
Thanks for the help. I've done some changes you suggested.
It seems to almost do what I want.
I want the part number to end with "- length" so in bill of materials it groups members with the same lenght.
However using "- "&{ length}  just uses the 100mm.
Also G_L still doesnt seem to map to length, it either maps to width or height and I cant figure out why.
Creating rectangle 1600x800mm frame of profile 40x40x4mm gives the part list as shown in "Example test.png"
I want the part number to be Aluminium gelijkzijdige koker 40x40x4mm - 1600mm (or 800mm for the other lenght)
Quantity: 2 (in this case 2 lenghts of 1600mm and 2 of 800mm)
Length linked to the 1600mm and 800mm
Somehow Thickness does seem to link correctly.
Length in the part list is linked to G_L
Message 25 of 42
bradeneuropeArthur
Do this for the part Number and the File Name columns:
And this  for the parameter mappings:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 26 of 42
Hi Branden,
Thank you, it seems to almost work.
Length now doesnt seem to update with driven length.
Would you know why?
Message 27 of 42
Ignore that, testing one more thing
Message 28 of 42
bradeneuropeArthur
What version of inventor are you using again?
maybe it is easier that I upload the idcl file than.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 29 of 42
I am currently using  professional 2016
Could you please check attached file.
I feel like I changed everything you said, but length still doesnt seem to update.
Part numbers just seem to get 100mm now, not updated and split in 1600mm and 800mm.
Also, length table seems empty
Message 30 of 42
Maybe its this:
Column properties of length, the mapping to custom.length was gone after I updated parameter mapping in family properties
Message 31 of 42
After updating that, length still seems 100mm
Message 32 of 42
bradeneuropeArthur
Do the same with the Length and the height and thickness as with the "width":
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 33 of 42
Hi Branden,
Problem still isn't fixed.
After all these adjustments the G_L still doesn't give the length in the part list.
Also the part number still shows 100mm instead of 800mm and 1600mm.
Message 34 of 42
bradeneuropeArthur
My result is as following:
So it seems that we did not do exactly the same!!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 35 of 42
In family properties > Template Parameters
I set width to width and thickness to thickness, click apply and ok.
then if I open the template parameters again immediately, the width and thickness are gone
Message 36 of 42
bradeneuropeArthur
Do the following;
remove all values marked in red
then the length should appear automatically
the other need to be defined new after delete
and it should look like:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 37 of 42
Hi Branden,
Could you please look at attached files again.
I even looked at capital letters, I just can't seem to get it correctly.
Message 38 of 42
bradeneuropeArthur
Please use my inventor 2018 .idcl file.
Because on your side some crucial steps are missing.
Maybe some training is very useful, because if the CC tables are to be migrated or handled in future you must be very careful with also little mistakes.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 39 of 42
Hi Branden,
After changing the family properties as shown in the attachment (setting lenght to lenght) it seems to work exacly as I want.
Message 40 of 42
bradeneuropeArthur
Change this for the length and you are ready.
This makes it possible to use every length.....
Could you please mark this as solved then!!!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
