Adding content center structural shapes - Bill of materials
Message 1 of 42
Good day,
I'm going to add extra structural shapes in Inventor for work.
As a test I started with a simple iPart, created a square tube with parameters length, width, height and thickness.
After that I added about 50 different profiles in excel, published the shape with the structural shape publisher.
Then I created an assembly using a configuration of the new family I added, even that works perfectly.
Where I bumb into a problem is the part list. In the column length, the part list shows the height of the profile, instead of the length.
See screencast for reference, it should show 2x 500mm and 2x 200mm but shows 2x 20mm, 1x 20mm and 1x 20mm for some reason.
I hope someone can fix this for me.
Thanks in advance.
Sjors
Replies (41)
Message 2 of 42
bradeneuropeArthur
Can you provide the library file.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 42
This is the iPart
Message 4 of 42
bradeneuropeArthur
I need the idcl library file
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 42
Can you ellaborate. This doesn't make sense to me whatsoever.
Message 6 of 42
bradeneuropeArthur
I need to be able to take a look in the Content center Library table.
You wrote that you published the ipart to Content center, right?
So these definitions need to be visible to be able to help you.
I need to see i.e. where and how the parameter length is mapped to.
This is an example form Content Center:
Does this make it clear for you?
if not please let me know.
Also if you are not knowing how to do this.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 42
I do not know how to share a content center file
If you need this, please tell me how to share this with you
Message 8 of 42
bradeneuropeArthur
are you using Desktop Content Center?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 42
I have no idea, probably not
for family parameter mapping see attached file
Message 10 of 42
As I said, everythign works fine, but the parameter length wont show up in the BOM as length
Message 11 of 42
In bill of materials, G_L is set to length
Length G_L is the driven length generated in a frame member
so I have no idea why the part list wont show the correct length
Message 12 of 42
bradeneuropeArthur
Is it already a content center file you are talking about?
Are you using vault?
How can you publish to content center if uou don't know what kind of Cc you use!?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 42
I publish in a custom library which publishes to vault.
However, publishing a structural shape to the content center doesnt create a content center file in vault.
Message 14 of 42
I could send alot of iparts which I published in the content center, but this is not the case for structural shapes as far as I know
Message 15 of 42
bradeneuropeArthur
But then I know that you don't use desktop Cc.
Please do the following.
Go to you projects explorer
And create a desktop Cc from the custom library.
And you are able to share this.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 42
bradeneuropeArthur
I think you don't understand me right.
Cc is s table.
I need to be able to take a look into that table.
You understand?
for example if you publish a I-part file to CC then there is a table created. Not more and not less.
With this table files are only then created when they are first used.
For me the I-part selves says nothing about why it is not shown in the Bom correctly, because there is a translation publishing it to CC.
Cc are no iparts actually!
Please let me know is you are willing to try this and if you are able to do this.
if not ask your System admin or Cadmanager to help you.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 42
I can add the table after the weekend
It has the following columns: file name, part number, length, width, height and thickness
Message 18 of 42
Here is the family table, do you mean that?
Message 19 of 42
bradeneuropeArthur
No,
I need the table.
These tables are *.idcl files.
I need to investigate the table formats in Inventor.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 20 of 42
I dont know how to share that
