New Bill of Materials
New Bill of Materials for Inventor
Industrial Revolution 4.0 -) Thank you for voting
English version
Kusovnik_EN1.pngFor Drawing
Functions:
1. filter-settings-for-bill-of-materials
https://forums.autodesk.com/t5/inventor-ideas/filter-settings-for-bill-of-materials/idi-p/6777047
2. allow-undo-in-bom
http://forums.autodesk.com/t5/inventor-ideas/allow-undo-in-bom/idc-p/6535801#M14070
3. bill-of-materials-always-open
http://forums.autodesk.com/t5/inventor-ideastation/bill-of-materials-always-open-assembly-mode/idi-p...
4. inventor-renaming-tool-without-vault/
http://forums.autodesk.com/t5/inventor-ideastation/inventor-renaming-tool-without-vault/idi-p/390972...
- NEXT RENAMING
https://forums.autodesk.com/t5/inventor-ideas/ilogic-design-copy-new-function/idi-p/7603482
5. create-drop-down-menu-part-fx-user-parameter-to-assembly-bill-of
https://forums.autodesk.com/t5/inventor-ideas/create-drop-down-menu-part-fx-user-parameter-to-assemb...
6. link-parts-list-to-excel-automatically
https://forums.autodesk.com/t5/inventor-ideas/link-parts-list-to-excel-automatically/idc-p/6776965#M...
7. frame-generator-change-definitions-the-item-in-a-bill-of
https://forums.autodesk.com/t5/inventor-ideas/frame-generator-change-definitions-the-item-in-a-bill-...
8. bill-of-materials-in-ipt-for-multibody
https://forums.autodesk.com/t5/inventor-ideas/bill-of-materials-in-ipt-for-multibody/idi-p/7519167
9. more-keys-for-parts-list
https://forums.autodesk.com/t5/inventor-ideas/more-keys-for-parts-list/idi-p/7690004
10. TOTAL WEIGHT
- I choose items I want to put in weight or check All weight for all items
11. COMBINATION BILL OF MATERIALS
- We have 300,000 to 500,000 active components (Total Occurences in Activ Document) for one or more, so the main assemblies are done in AutoCAD. Function: using the button = COMBINATION BILL OF MATERIALS= I label the reports in a folder, this information loads me to the BILL OF MATERIALS, I count all the same pieces and I can make BILL OF MATERIALS for the main assembly. This can then be printed and attached to the AutoCAD main assembly. If I change something in Inventor, I will always have my current BILL OF MATERIALS.
12. LIST OF DRAWING DOCUMENTATION
- List all drawings from top to bottom. Layout of drawings
13. BUTTON Apply
14. summary-print
https://forums.autodesk.com/t5/inventor-ideas/summary-print/idi-p/8357049
15. PRINT- I can select all items to print or just some.
16. ZOOM
17. The ability to create rows without having to use a virtual component.
18. When we create a drawing and save it, it will appear in (BILL OF MATERIALS / PARTS LIST) DRAWING FORMAT as described in the drawing that we already created a drawing
19. The status item is already created, just use it, we know in the drawing if the drawing is already approved. This item applies to the model, but the model and the drawing must agree, so when approved, this will apply to the model and the drawing at the same time. In spite of the selection, it should be possible to mark all items and to approve all at once.
20. qty-for-multi-body-pattern-bill-of-materials
https://forums.autodesk.com/t5/inventor-ideas/qty-for-multi-body-pattern-bill-of-materials/idi-p/827...
21. WEIGHT FOR VIEW REPRESENTATION, TO DRAW FILTR FOR LEVEL OF DETAILS
- Currently, we get weight with levels of detail, but we are not able to get a detail level filter for the drawing. We are able to turn on the representation view filter for the drawing, but we do not get weight. If we copy the detail level to the view of the representation, then we will change something in the level of detail so the changes will not automatically be reflected in the view. We must delete the view of the representation, re-transfer the new level of detail to the view of the representation, and then turn the detail level again into the drawing.
22. I hope it will be in new BILL OF MATERIALS to implement the level of detail for parts
https://forums.autodesk.com/t5/inventor-ideas/level-of-detail-for-parts/idi-p/3822718
Czech version
Pro výkres:
Funkce:
 1. FILTR PRO ROZPISKU
2. FUNKCE ZPĚT A V PŘED PRO ROZPISKU
3. ROZPISKA VŽDY OTEVŘENÁ
4. PŘEJMENOVÁNÍ SOUBORŮ BEZ VAULT
- DOPLNĚNÍ PŘEJMENOVÁNÍ
5. VYTVOŘIT MENU SEZNAM PRO-fx-UŽIVATELSKÉ PARAMETRY V ROZPISCE
6. link-ROZPISKA DO EXCELU AUTOMATICKY
7. frame-generator-ZMĚNA DEFINICE PRO POLOŽKY V ROZPISCE
8. ROZPISKA PRO OBJEMOVÁ TĚLESA IPT
9. VÍCE VARIANT PRO KUSOVNÍK
10. CELKOVÁ HMOTNOST
- Vyberu si položky, které chci dát do hmotnosti nebo zaškrtnu All hmotnost pro všechny položky.
11. KOMBINACE KUSOVNÍKŮ
- Máme sestavy o 30000až50000 aktivních komponentách (Total Occurences in Activ Dokument) někdo i více proto se hlavní sestavy dělají v AutoCadu. Funkce: přes tlačítko =KOMBINACE KUSOVNÍKU= označím sestavy ve složce, tyto informace se mi načtou do kusovníku, spočítají se mi všechny stejné kusy a můžu dělat kusovník pro hlavní sestavu. Toto pak můžu vytisknout a přiložit k hlavní sestavě v AutoCadu. Pokud změním něco v Inventoru, vždy budu mít aktuální hlavní kusovník.
12. SEZNAM VÝKRESOVÉ DOKUMENTACE
- Seznam všech výkresu shora dolů. Rozpad výkresů
13. TLAČÍTKO POUŽÍT
14. HROMADNÝ TISK
15. TISK-Můžu vybrat všechny položky k tisku nebo jen některé.
16. ZOOM
17. Možnost vytvářet řádky bez nutnosti použití virtuální komponenty
18. Když vytvoříme výkres a uložíme ho, objeví se v rozpisce/kusovník FORMÁT podle toho poznáme v rozpisce, že již jsme vytvářeli výkres
19. Položka stavu je již vtvořena, stačí jen použít, poznáme u výkresu, jestli je už výkres schválen. Tato položka platí sice pro model, ale model a výkres musí souhlasit, proto když dáme schváleno, bude to platit pro model i výkres současně. Přes výběr by mělo být možné označit všechny položky a všechny schválit najednou
20. SEČTENÍ A ROZPOZNÁNÍ OBJEMOVÝCH TĚLES V ROZPISCE PO PŘEVODU
21. HMOTNOST PRO POHLEDOVOU REPREZENTACI, FILTR DO VÝKRESU PRO ÚROVEŇ DETAILU
- V současnosti získáme hmotnost s úrovně detailu, ale nejsme schopni získat filtr úrovně detailu pro výkres. Jsme schopní zapnout filtr Pohledu reprezentace pro výkres, ale nedostaneme s pohledu hmotnost. Pokud zkopírujeme úroveň detailu do pohledu reprezentace, tak potom něco změníme v úrovni detailu, tak se nám změny nepromítnou automaticky do pohledu. Musíme daný pohled reprezentace smazat, znovu přenést novou úroveň detailu do pohledu reprezentace a pak zase zapnout úroveň detailu ve výkresu.
22.Doufám, že bude v novém kusovníku úroveň detailu pro ipt
22 Comments
dusan.naus.trz
Ability to connect to the Bill of Materials. For Drawing
https://forums.autodesk.com/t5/inventor-ideas/manager-view/idi-p/8360512
dusan.naus.trz
Point 23, Next Option together with point 6
Cumulative Bill of materials. One Project. All Assemblies, all parts. Sum of profile types, their lengths. I have one project and I have to pass data for the production and for the purchase of the material.
DRoam
dusan.naus.trz
dusan.naus.trz
dusan.naus.trz
Next Context
Point 5. Industrial revolution 4.0
https://www.youtube.com/watch?v=QOpITqXMoAo
dusan.naus.trz
dusan.naus.trz
Point.27
It would be interesting to create for Bill of Materials and Part List
https://forums.autodesk.com/t5/inventor-ideas/qr-code-support-for-inventor-iproperties-and-text/idc-...
dusan.naus.trz
dusan.naus.trz
Point.29
Dark mode for background and the whole dialogue BOM
Context
https://forums.autodesk.com/t5/inventor-ideas/dark-mode-for-dialog-window/idc-p/10321572#M42202
dusan.naus.trz
Point.30
Maybe it will add to someone? Maybe it will add to someone? If yes, then vote. It was late yesterday. 🙂
https://forums.autodesk.com/t5/inventor-ideas/find-value-for-bom/idi-p/10321662
dusan.naus.trz
jimmymitchell5369
While you are updating the BOM system add this change. Currently you can only edit parts and assemblies below the currently assembly. Include the current assembly to all the fields that you can edit.
dusan.naus.trz
Calculating QTY based on Part Number in the 21st century is quite weak. The future and development of he in the dynamic calculation of QTY according to Mass and Area for a given unit. Those who work as a mechanical engineer will understand.
The possibilities of BOM and Part of List are insufficient for me and limit me in my work and development of new equipment.
Don't Look Up 😞
dusan.naus.trz
Next Context Multivalue for iProperties it follows on from position 5
https://forums.autodesk.com/t5/inventor-ideas/multivalue-for-iproperties/idi-p/10951802
dusan.naus.trz
Next Context = Bom Import and Export for Sort by and all Settings
feedback number PR: 3793
https://forums.autodesk.com/t5/inventor-ideas/bom-import-and-export-for-sort-by-and-all-settings/idi...
dusan.naus.trz
Next Context = Structured BoM - all Levels = We want There inheritance between them
https://forums.autodesk.com/t5/inventor-forum/structured-bom-all-levels/td-p/10533456
dusan.naus.trz
Next Context
Item BOM to model
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-transcription-bom-item-number...
Total QTY to model
https://forums.autodesk.com/t5/inventor-forum/ilogic-to-create-custom-iproperty-in-sub-component/td-...
List of assemblies in which the model is included in the table on the drawing.
I would like to be able to open the parent assembly!!!
Lots of people write on the internet. A lot of people are asking about many features, which will be when?
I guess I'm not in the 21st century.
The processes are not smart enough, they do not correspond to the century. The processes do not correspond to the real work of a Mechanical Engineer for the development of large machines.
The user wants to have an overview of the drawings, he wants to correct a lot of drawings.
It would be nice if:
The drawing should have a table that contains which assemblies it enters
example
Item 1; Assembly 1; Quantity
Item 1; Assembly 2; Quantity
Item 1; Assembly 3; Quantity
When I print the drawings, the drawings should be sorted in the structure from top to bottom, each printed sheet should have a number from 1 to . so that someone can easily and quickly arrange the drawing sheets.
Mass printing should automatically distinguish printers for A4 and A3 and another printer for larger formats.
There should be an option to print 1 format smaller for correction.
Sometimes I feel like the developers never designed big machines.
dusan.naus.trz
context = iLogic Open Top Assemblies and Numbers to Drawing
https://www.youtube.com/watch?v=j4ce8nACd1g&t=368s
