New Bill of Materials
New Bill of Materials for Inventor
Industrial Revolution 4.0 -) Thank you for voting
English version
Kusovnik_EN1.pngFor Drawing
Functions:
1. filter-settings-for-bill-of-materials
https://forums.autodesk.com/t5/inventor-ideas/filter-settings-for-bill-of-materials/idi-p/6777047
2. allow-undo-in-bom
http://forums.autodesk.com/t5/inventor-ideas/allow-undo-in-bom/idc-p/6535801#M14070
3. bill-of-materials-always-open
http://forums.autodesk.com/t5/inventor-ideastation/bill-of-materials-always-open-assembly-mode/idi-p...
4. inventor-renaming-tool-without-vault/
http://forums.autodesk.com/t5/inventor-ideastation/inventor-renaming-tool-without-vault/idi-p/390972...
- NEXT RENAMING
https://forums.autodesk.com/t5/inventor-ideas/ilogic-design-copy-new-function/idi-p/7603482
5. create-drop-down-menu-part-fx-user-parameter-to-assembly-bill-of
https://forums.autodesk.com/t5/inventor-ideas/create-drop-down-menu-part-fx-user-parameter-to-assemb...
6. link-parts-list-to-excel-automatically
https://forums.autodesk.com/t5/inventor-ideas/link-parts-list-to-excel-automatically/idc-p/6776965#M...
7. frame-generator-change-definitions-the-item-in-a-bill-of
https://forums.autodesk.com/t5/inventor-ideas/frame-generator-change-definitions-the-item-in-a-bill-...
8. bill-of-materials-in-ipt-for-multibody
https://forums.autodesk.com/t5/inventor-ideas/bill-of-materials-in-ipt-for-multibody/idi-p/7519167
9. more-keys-for-parts-list
https://forums.autodesk.com/t5/inventor-ideas/more-keys-for-parts-list/idi-p/7690004
10. TOTAL WEIGHT
- I choose items I want to put in weight or check All weight for all items
11. COMBINATION BILL OF MATERIALS
- We have 300,000 to 500,000 active components (Total Occurences in Activ Document) for one or more, so the main assemblies are done in AutoCAD. Function: using the button = COMBINATION BILL OF MATERIALS= I label the reports in a folder, this information loads me to the BILL OF MATERIALS, I count all the same pieces and I can make BILL OF MATERIALS for the main assembly. This can then be printed and attached to the AutoCAD main assembly. If I change something in Inventor, I will always have my current BILL OF MATERIALS.
12. LIST OF DRAWING DOCUMENTATION
- List all drawings from top to bottom. Layout of drawings
13. BUTTON Apply
14. summary-print
https://forums.autodesk.com/t5/inventor-ideas/summary-print/idi-p/8357049
15. PRINT- I can select all items to print or just some.
16. ZOOM
17. The ability to create rows without having to use a virtual component.
18. When we create a drawing and save it, it will appear in (BILL OF MATERIALS / PARTS LIST) DRAWING FORMAT as described in the drawing that we already created a drawing
19. The status item is already created, just use it, we know in the drawing if the drawing is already approved. This item applies to the model, but the model and the drawing must agree, so when approved, this will apply to the model and the drawing at the same time. In spite of the selection, it should be possible to mark all items and to approve all at once.
20. qty-for-multi-body-pattern-bill-of-materials
https://forums.autodesk.com/t5/inventor-ideas/qty-for-multi-body-pattern-bill-of-materials/idi-p/827...
21. WEIGHT FOR VIEW REPRESENTATION, TO DRAW FILTR FOR LEVEL OF DETAILS
- Currently, we get weight with levels of detail, but we are not able to get a detail level filter for the drawing. We are able to turn on the representation view filter for the drawing, but we do not get weight. If we copy the detail level to the view of the representation, then we will change something in the level of detail so the changes will not automatically be reflected in the view. We must delete the view of the representation, re-transfer the new level of detail to the view of the representation, and then turn the detail level again into the drawing.
22. I hope it will be in new BILL OF MATERIALS to implement the level of detail for parts
https://forums.autodesk.com/t5/inventor-ideas/level-of-detail-for-parts/idi-p/3822718
Czech version
Pro výkres:
Funkce:
 1. FILTR PRO ROZPISKU
2. FUNKCE ZPĚT A V PŘED PRO ROZPISKU
3. ROZPISKA VŽDY OTEVŘENÁ
4. PŘEJMENOVÁNÍ SOUBORŮ BEZ VAULT
- DOPLNĚNÍ PŘEJMENOVÁNÍ
5. VYTVOŘIT MENU SEZNAM PRO-fx-UŽIVATELSKÉ PARAMETRY V ROZPISCE
6. link-ROZPISKA DO EXCELU AUTOMATICKY
7. frame-generator-ZMĚNA DEFINICE PRO POLOŽKY V ROZPISCE
8. ROZPISKA PRO OBJEMOVÁ TĚLESA IPT
9. VÍCE VARIANT PRO KUSOVNÍK
10. CELKOVÁ HMOTNOST
- Vyberu si položky, které chci dát do hmotnosti nebo zaškrtnu All hmotnost pro všechny položky.
11. KOMBINACE KUSOVNÍKŮ
- Máme sestavy o 30000až50000 aktivních komponentách (Total Occurences in Activ Dokument) někdo i více proto se hlavní sestavy dělají v AutoCadu. Funkce: přes tlačítko =KOMBINACE KUSOVNÍKU= označím sestavy ve složce, tyto informace se mi načtou do kusovníku, spočítají se mi všechny stejné kusy a můžu dělat kusovník pro hlavní sestavu. Toto pak můžu vytisknout a přiložit k hlavní sestavě v AutoCadu. Pokud změním něco v Inventoru, vždy budu mít aktuální hlavní kusovník.
12. SEZNAM VÝKRESOVÉ DOKUMENTACE
- Seznam všech výkresu shora dolů. Rozpad výkresů
13. TLAČÍTKO POUŽÍT
14. HROMADNÝ TISK
15. TISK-Můžu vybrat všechny položky k tisku nebo jen některé.
16. ZOOM
17. Možnost vytvářet řádky bez nutnosti použití virtuální komponenty
18. Když vytvoříme výkres a uložíme ho, objeví se v rozpisce/kusovník FORMÁT podle toho poznáme v rozpisce, že již jsme vytvářeli výkres
19. Položka stavu je již vtvořena, stačí jen použít, poznáme u výkresu, jestli je už výkres schválen. Tato položka platí sice pro model, ale model a výkres musí souhlasit, proto když dáme schváleno, bude to platit pro model i výkres současně. Přes výběr by mělo být možné označit všechny položky a všechny schválit najednou
20. SEČTENÍ A ROZPOZNÁNÍ OBJEMOVÝCH TĚLES V ROZPISCE PO PŘEVODU
21. HMOTNOST PRO POHLEDOVOU REPREZENTACI, FILTR DO VÝKRESU PRO ÚROVEŇ DETAILU
- V současnosti získáme hmotnost s úrovně detailu, ale nejsme schopni získat filtr úrovně detailu pro výkres. Jsme schopní zapnout filtr Pohledu reprezentace pro výkres, ale nedostaneme s pohledu hmotnost. Pokud zkopírujeme úroveň detailu do pohledu reprezentace, tak potom něco změníme v úrovni detailu, tak se nám změny nepromítnou automaticky do pohledu. Musíme daný pohled reprezentace smazat, znovu přenést novou úroveň detailu do pohledu reprezentace a pak zase zapnout úroveň detailu ve výkresu.
22.Doufám, že bude v novém kusovníku úroveň detailu pro ipt
22 Comments
dusan.naus.trz
dusan.naus.trz
