Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Error in launching Inventor 2013
3 REPLIES 3
684 Views, 3 Replies
Inventor Fusion 2013 cannot be launched on Windows 10. Autodesk Inventor SP_2 was downloaded but cannot be installed due to below error:
Inventor Publisher 2013 R1 Update ErrorWhat shall be the solution?
3 REPLIES 3
OP21
You may want to look at this link...
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Window...
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
TravisNave
The above post is correct.  Windows 10 is not supported for 2013 products.  If you recently updated to Windows 10, you can still uninstall it and go back to Windows 7/8.x.  I would recommend doing so.
Autodesk Forums:
in reply to: OP21
But my Autocad 2013 is working perfect. The problem is only with inventor add-in.
