What I can remember but not find anymore is the following.
I have for example 4 the same holes in a part not created with a pattern.
Now I can remember that if that part is used in a assembly I could still place bolts and let the 4 holes create the additional 3 bolts in place of that holes.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
@bradeneuropeArthur
Hi Arthur,
It has been a while, but I remember having to select each hole individually if the holes were not created using the Pattern command. That would probably have been in IV2021, so I don't know if that has changed since then.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Hi Arthur
This works with the bolted joint generator or insert from CC.
These commands recognize the hole modeling operation (for multiple points simultaneously).
Can you record your workflow to demonstrate the problem?
Kacper Suchomski
Hi! The auto-populating workflow is available in iMate. If you added iMate (Insert) to each hole in the part, when placing the bolt, the bolts will be automatically inserted to the holes.
Many thanks!
