Change the inventor drawing sheet background color to white
lkirit2000
Advisor Advisor
lkirit2000
Hi Team,
I need to change the background of my inventor drawing sheet to white.
I tried, it changes to part environment to white, but not in the drawing sheet.
How Can I do that?
WHolzwarth
Open your Standard.IDW in the templates folder
- Tools -> Document settings  -> Sheet
- In Colors, click on Sheet
- Select new color as background
- Save back to your templates folder
Walter Holzwarth
Lars_Greft
If you go to "Tools" --> "Document Settings" --> "Sheet", here you can change the sheet color.
This only shows a white background for the drawing file you have open, if you want it for all drawings as default you have to do this within the template file.
Chris_FS7DWQ
Observer
Observer
Do you know of a way to have each sheet within a drawing file a different color?
johnsonshiue
Hi Chris,
Unfortunately, it is not doable. All sheets share the same background color. It is a document-level setting. You will need to have multiple idw/dwg files to have different sheet background colors.
Many thanks!
Software Test Engineer
davis.j
This should be a user setting/client-level setting, not document level. 🤔
A designer shouldn't be bound by another designer's preference to burn his eyes all day. 🥲
