Inventor Forum
Pattern Recognition
5 REPLIES 5
bradeneuropeArthur
249 Views, 5 Replies
Pattern Recognition
bradeneuropeArthur
What I can remember but not find anymore is the following.
I have for example 4 the same holes in a part not created with a pattern.
Now I can remember that if that part is used in a assembly I could still place bolts and let the 4 holes create the additional 3 bolts in place of that holes.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Pattern Recognition
Arthur Knoors
5 REPLIES 5
CGBenner
@bradeneuropeArthur
Hi Arthur,
It has been a while, but I remember having to select each hole individually if the holes were not created using the Pattern command.  That would probably have been in IV2021, so I don't know if that has changed since then.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
@bradeneuropeArthur
Hi Arthur,
Chris Benner
kacper.suchomski
Hi Arthur
This works with the bolted joint generator or insert from CC.
These commands recognize the hole modeling operation (for multiple points simultaneously).
Can you record your workflow to demonstrate the problem?
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Hi Arthur
Kacper Suchomski
johnsonshiue
Hi! The auto-populating workflow is available in iMate. If you added iMate (Insert) to each hole in the part, when placing the bolt, the bolts will be automatically inserted to the holes.
Many thanks!
Software Test Engineer
Many thanks!
CGBenner
@bradeneuropeArthur Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Chris Benner
SBix26
in reply to: bradeneuropeArthur
SBix26
When placing fasteners from the Content Center, AutoDrop may be turned on or off.  If AutoDrop is turned on, Place from Content Center will attempt to select the correct bolt (for example) size for the selected hole; it will also identify all identical holes on the same face.  You then have a pull glyph to use for graphically setting the length of the bolt from among the lengths specified in the CC table.  Finishing the command places the chosen bolt in all the identified holes.  Note, though, that they are not related in any way as they would be with a component pattern.  Each is an individual instance.
Sam B
Inventor Pro 2025.1.1 | Windows 11 Home 23H2
Sam B
