Installation & Licensing
Where can I download the .lic License file? URGENT!!
1 REPLY 1
3556 Views, 1 Reply
Hi All,
When Autodesk email us the Registration & Activations email the attached LIC file is missing. It advises me to simply input the Activation code into a text file and rename it with a .lic extension. However I am sure just this information is not sufficient for LMtools to correctly read the file. If someone could kindly provide me with all the required fields for .lic file that would be very much appreciated.
Regards
Steven
1 REPLY 1
TravisNave
Oops! Yeah, -2 is invalid syntax, so your license file is definitey corrupted. You need to copy and paste the portion of that email that begins with SERVER and includes your hostname and MAC address. End the file after your last product increment and make sure that all the quotes are included.
You will want to do this in notepad and save the file with a .LIC extension (making sure there is no .txt) and point your LMTOOLS to it.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
