Installation & Licensing
Unable to install Revit 2015
3 REPLIES 3
921 Views, 3 Replies
Hello!
I hope someone can help as I have been troubleshooting this for quite some time.
I have recently downloaded Revit 2015 and have included a manifest file in plugin folder but the "External Tools" are not appearing. My Revit 2015 was unable to run "Revit Lookup"
I have uninstalled in and now I have trouble re-installing it. With all the 3 download optios (Install Now, Download Now and Browser Download) all giving me errors.
-Install Now gives an error of "The System cannot open the device or file spcified. C:\Users\a0086042\AppData\Local\Temp\_AI890D.tmp\x64\en-us\Tools\NLM\-t.msi"
-Browser download gave "File Corrupted Error"
-Download Now gave "Connection has expired. Please reconnct to site."
Thank you for the help in advance!
You Long
3 REPLIES 3
TravisNave
First make sure you are downloading with your antivirus temporarily disabled.  This is especially true if you are running Trend Micro or Avast.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
in reply to: TravisNave
Hi Travis,
Thank you so much for the reply and the suggestion. I have tried your method but I still face the problem of "File Corrupted" after downloading the file.
My TrendMicro was off.
You Long
Hi Travis,
I have managed to successfully installed Revit2015. The problem apparantly was that my other Anti-Virus (which I didn't know existed) was still On during my installation.
Anyhow, thank you and have a good day.
You Long
Administrator Productivity
