Installation & Licensing
Transfer stand alone license to a computer with subscription license?
4 REPLIES 4
jmagaha
388 Views, 4 Replies
Hello.  A coworker with a stand alone license of AutoCAD2015 will be on maternity leave in the next month.  I would like to utilize her license while she is gone.  I currently have a subscription monthly license.
Best way to make that happen?  I was thinking cancelling my subscription and transfer her license to my machine.  Is that the smartest solution?  I suppose I could simply use her laptop with AutoCAD, but I really don't want to go between 2 laptops to do my work.
Kathryn Costanzo
4 REPLIES 4
TravisNave
in reply to: jmagaha
Use the license transfer utility to move the license from the laptop to your computer.  You should be good to go.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
rkmcswain
and in case you need this..... License Transfer Utility
R.K. McSwain     | CADpanacea | on twitter
jmagaha
in reply to: TravisNave
Thanks Travis.  I was hoping that would be the case.  I was just unsure due to the different type of licenses involved.  I assume that I would need to cancel my subscription first... 🙂
TravisNave
Well, if you are paying monthly, then you might consider it.  It really depends on how long you will transfer the license and if you plan on picking it back up again when you give the license back.  If it is worth the $$$, then do so.
Autodesk Forums:
Administrator Productivity
