Revit LT SP1 Installation Issue
Hi.
When installing Revit LT SP1, I get an "Error 1328 applying patch to file C:\Config.msi\PT11F0.tmp It has probably been updated by other means, and can no longer be modified by this patch. For more imformation contact your patch vendor." that I can not get past until I select cancel - at which time the installation progress bar steps backward as if it is un-doing what has been updated.
I have never had any issue with updates fot my Revit LT Suite since inatalling 2015 with any updates.
Since this fist happened, I un-insatalled Revit LT and then re-installed and immediately had the SP1 show up in Application Manager and installed with the same error - a screen grab is attached showing the dialogues.
The 'About Dialgue' does not show the updated build number.
This is on a hp Z400 worksation Win-7 64 with all updates insatlled.
I found similar posts through searches, but nothing has led me to a solution.
Barry.
