Solved by TravisNave. Go to Solution.
Post your installation log file and I can take a look at why it is failing.
Thanks for replying.. here is my installation log file.. and thanks again for the help
2015/12/3:21:38:29 hamed_000 DALILI === Setup started on DALILI by hamed_000 ===
2015/12/3:21:38:29 hamed_000 DALILI Path_Length: 155
2015/12/3:21:38:29 hamed_000 DALILI Current Directory C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-US
2015/12/3:21:38:29 hamed_000 DALILI Launch
2015/12/3:21:38:29 hamed_000 DALILI CommandLine /PK ***** /SN ***-******* /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-...
2015/12/3:21:38:29 hamed_000 DALILI Current Directory C:\Users\HAMED_~1\AppData\Local\Temp\_AI4321.tmp
2015/12/3:21:38:31 hamed_000 DALILI === Setup ended ===
2015/12/3:21:38:30 hamed_000 DALILI === Setup started on DALILI by hamed_000 ===
2015/12/3:21:38:30 hamed_000 DALILI Path_Length: 155
2015/12/3:21:38:30 hamed_000 DALILI Current Directory C:\Users\HAMED_~1\AppData\Local\Temp\_AI4321.tmp
2015/12/3:21:38:30 hamed_000 DALILI Launch
2015/12/3:21:38:30 hamed_000 DALILI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUPMARK...
2015/12/3:21:38:30 hamed_000 DALILI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUP_x64...
2015/12/3:21:38:30 hamed_000 DALILI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\HAMED_~1\AppData\Local\Temp\_AI4321.tmp\Setup\RevitSetup.dll
2015/12/3:21:38:30 hamed_000 DALILI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/12/3:21:38:31 hamed_000 DALILI PageOpen LaunchDialog
2015/12/3:21:50:14 hamed_000 DALILI === Setup started on DALILI by hamed_000 ===
2015/12/3:21:50:14 hamed_000 DALILI Path_Length: 155
2015/12/3:21:50:14 hamed_000 DALILI Current Directory C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-US
2015/12/3:21:50:14 hamed_000 DALILI Launch
2015/12/3:21:50:14 hamed_000 DALILI CommandLine /PK ***** /SN ***-******** /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-...
2015/12/3:21:50:14 hamed_000 DALILI Current Directory C:\Users\HAMED_~1\AppData\Local\Temp\_AID6A.tmp
2015/12/3:21:52:10 hamed_000 DALILI === Setup ended ===
2015/12/3:21:50:15 hamed_000 DALILI === Setup started on DALILI by hamed_000 ===
2015/12/3:21:50:15 hamed_000 DALILI Path_Length: 155
2015/12/3:21:50:15 hamed_000 DALILI Current Directory C:\Users\HAMED_~1\AppData\Local\Temp\_AID6A.tmp
2015/12/3:21:50:15 hamed_000 DALILI Launch
2015/12/3:21:52:09 hamed_000 DALILI Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUPMARK...
2015/12/3:21:52:10 hamed_000 DALILI Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUP_x64...
2015/12/3:21:52:10 hamed_000 DALILI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\HAMED_~1\AppData\Local\Temp\_AID6A.tmp\Setup\RevitSetup.dll
2015/12/3:21:52:10 hamed_000 DALILI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/12/3:21:52:10 hamed_000 DALILI PageOpen LaunchDialog
2015/12/3:21:52:16 hamed_000 DALILI Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\HAMED_~1\AppData\Local\Temp\_AID6A.tmp\Setup\RevitSetup.dll
2015/12/3:21:52:16 hamed_000 DALILI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2016. URLTitle= URLLink=
2015/12/9:21:33:07 hamed_000 DALILI === Setup started on DALILI by hamed_000 ===
2015/12/9:21:33:07 hamed_000 DALILI Path_Length: 155
2015/12/9:21:33:07 hamed_000 DALILI Current Directory C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_dlm
2015/12/9:21:33:07 hamed_000 DALILI Launch
2015/12/9:21:33:07 hamed_000 DALILI CommandLine
2015/12/9:21:33:07 hamed_000 DALILI Current Directory C:\Users\HAMED_~1\AppData\Local\Temp\_AIE79C.tmp
2015/12/9:21:33:10 hamed_000 DALILI === Setup ended ===
2015/12/9:21:33:08 hamed_000 DALILI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\HAMED_~1\AppData\Local\Temp\_AIE79C.tmp\Setup\RevitSetup.dll
2015/12/9:21:33:08 hamed_000 DALILI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/12/9:21:33:09 hamed_000 DALILI Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\HAMED_~1\AppData\Local\Temp\_AIE79C.tmp\Setup\RevitSetup.dll
2015/12/9:21:33:09 hamed_000 DALILI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2016. URLTitle= URLLink=
2015/12/9:21:33:10 hamed_000 DALILI PageOpen LaunchDialog
2015/12/9:21:33:12 hamed_000 DALILI PageOpen LicenseDialog
2015/12/9:21:33:15 hamed_000 DALILI PageOpen ProductInfoDialog
2015/12/9:21:33:58 hamed_000 DALILI PageOpen ProductSelectionDialog2
2015/12/9:21:46:27 hamed_000 DALILI PageOpen FullProgressDialog
2015/12/9:21:46:27 hamed_000 DALILI Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\HAMED_~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/12/9:21:46:29 hamed_000 DALILI Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2015/12/9:21:46:29 hamed_000 DALILI PageOpen InstallCompleteDialog
2015/12/9:21:46:45 hamed_000 DALILI === Setup ended ===
2015/12/10:20:13:50 hamed_000 DALILI === Setup started on DALILI by hamed_000 ===
2015/12/10:20:13:50 hamed_000 DALILI Path_Length: 155
2015/12/10:20:13:50 hamed_000 DALILI Current Directory C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_dlm
2015/12/10:20:13:50 hamed_000 DALILI Launch
2015/12/10:20:13:50 hamed_000 DALILI CommandLine
2015/12/10:20:13:50 hamed_000 DALILI Current Directory C:\Users\HAMED_~1\AppData\Local\Temp\_AIAE9E.tmp
2015/12/10:20:13:53 hamed_000 DALILI === Setup ended ===
2015/12/10:20:13:51 hamed_000 DALILI === Setup started on DALILI by hamed_000 ===
2015/12/10:20:13:51 hamed_000 DALILI Path_Length: 155
2015/12/10:20:13:51 hamed_000 DALILI Current Directory C:\Users\HAMED_~1\AppData\Local\Temp\_AIAE9E.tmp
2015/12/10:20:13:51 hamed_000 DALILI Launch
2015/12/10:20:13:51 hamed_000 DALILI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\HAMED_~1\AppData\Local\Temp\_AIAE9E.tmp\Setup\RevitSetup.dll
2015/12/10:20:13:51 hamed_000 DALILI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/12/10:20:13:52 hamed_000 DALILI Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\HAMED_~1\AppData\Local\Temp\_AIAE9E.tmp\Setup\RevitSetup.dll
2015/12/10:20:13:52 hamed_000 DALILI Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2016. URLTitle= URLLink=
2015/12/10:20:13:53 hamed_000 DALILI PageOpen LaunchDialog
2015/12/10:20:15:29 hamed_000 DALILI PageOpen LicenseDialog
2015/12/10:20:15:32 hamed_000 DALILI PageOpen ProductInfoDialog
2015/12/10:20:16:12 hamed_000 DALILI PageOpen ProductSelectionDialog2
2015/12/10:20:16:14 hamed_000 DALILI PageOpen FullProgressDialog
2015/12/10:20:16:14 hamed_000 DALILI Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\HAMED_~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/12/10:20:16:17 hamed_000 DALILI Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
hey Travis, i tried everything as per the instructions and i still get an error for the VC .. here am attaching my modified setup ini and the error screenshot and the latest installation error log file ..
thanks for the help..
if you can edit the setup.ini file and send me back i will be glad
It's a new error.
Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Failed Installation aborted, Result=1603
Need to edit here now:
[KB958314ATLX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (ATL) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\ATL\vc_atlx64runtime.msi
I am having trouble to install Revit 2016 on my desktop.. I got an i7 and I am using Windows 10..
Is there any incompatibility?
I already read the previous posts and uninstalled C++ from my computer before installing Revit... however.. it didnt work.
Thanks for any help you guys can give me..
I am posting the logs and a picture..
@Anonymous
First see my solution/response here (the last posting).
Then after the library is installed, then go to the Autodesk Virtual Agent and follow the download links to your product. Download all of the parts first (some applications may only have a single part to download) and then go to your download location. Extract (double click) part 1 (or the single part download) and in a few seconds the extraction will start. It will then prompt you to extract to C:\Autodesk and once the extraction is finished the installation will start. Also make sure you have admin rights, UAC is turned off and Anti-Virus temporary disabled prior to installation.
Mark Lancaster
& Autodesk Services MarketPlace Provider
