Installation & Licensing
Problem: Close program monitor.exe
6 REPLIES 6
4906 Views, 6 Replies
Hi all, i'm a italian student and I want installed 3Ds Max Trial, But when I started the installation there is this problem:
if you don't see it this is problem:
The installer has detected the following programs are running.
monitor.exe
In order to complete installation these programs must be closed
Choose OK to proced the installation
Choose Cancel to halt the installation.
This is Error, if i close monitor.exe, my monitor became black... I have a windows Vista 32 bit, I click ok but the program keeps giving me error.
Sorry for this English but i don't speak a good english
6 REPLIES 6
Steve_Curley
Very old thread on exactly the same topic:- http://area.autodesk.com/forum/t12213
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
in reply to: Steve_Curley
404 not found...thelink says..
help meeeeeeeeeeeeeeeeeeeeeeeCat Happy
Steve_Curley
Go to the main 3dsMax forum, type monitor.exe into the search box and click Search. There are many threads on this topic - one of them is likely the one linked above.
The entire forum system has changed since 2011 which is why the link is dead.
Max 2016 (SP1/EXT1)
I have the same problem. Did you manage to fix it or not
monitor.exe
TravisNave
Launch cmd prompt as administrator by right-clicking it and running as administrator.  Type taskkill /f /im monitor.exe and see if that will kill it.  Try again.
https://forums.autodesk.com/t5/installation-licensing/can-t-install-upgrades/m-p/3339293#M42694
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
very good solution! thank you very much!!
Administrator Productivity
