Installation & Licensing
New motherboard activation problem
2 REPLIES 2
777 Views, 2 Replies
After installing the new  WINDOWS 8 license, an error
2 REPLIES 2
pendean
Your screenshot says INSTALLED: it's done. Complete. Finished.
So no more space is needed.
TravisNave
Dean is right.  There is nothing wrong with the installation.  If you changed your mobo, then the activation is broken.  You simply need to delete the old license files and then launch and reactivate:
Delete these:
%programdata%\flexnet\adsk*.data
Good Luck.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
