Maya Not Installing Source File Not Found
So, I've scoured the internet hoping to find a download of this .dll file, but to no avail. I'd rather not re-install the program again, so I'm posting this here to see if anyone has had the same .dll file missing. I've searched the folder where it says it's located but it isn't there. I'm hoping that my download isn't corrupted, but that might be it.
Thanks in advance.
TravisNave
Make sure you install with your antivirus disabled.  This is a known issue.
http://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-Sour...
If you need a new download, use the Virtual Agent by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thank you for the reply, but as of this time I had already solved the problem; SuperAnti-Spyware was quaranting all of the files, so that's why I couldn't find them. It's only because I paid attention when installing thme this time that I caught that.
