Hi Guys,
I am having an issue with LMTools. I am running the latest version of LMTools (installed from the 2017 media kit).
I have the Autodesk software installed on the machine that LMTools is installed on. It has been working perfectly until yesterday when it could not find a license and it gave the error - 15.570.
I opened LMTools and tried to restart the server and it gave me the following error.
I checked the debug log file and it said the following.
When I go back to my START/STOP/REREAD tab it says at the bottom that I am using the correct license.
I run a Perform Status Enquiry and it brings up the following.
Status
Flexible License Manager status on Thu 8/11/2016 11:34
[Detecting lmgrd processes...]
License server status: @NP-Render2@Anonymous-Render2
License file(s) on NP-Render2: \\Np-render2\network license\NEW AUTODESK LICENCE\NP-Render2.lic:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: NP-Render2
License path: @NP-Render2;@Anonymous-Render2;
FlexNet Licensing error:-15,570
For further information, refer to the FlexNet Licensing documentation,
available at "www.flexerasoftware.com".
If I try and stop the service from local services on the PC it gives me the following error message.
Cannot stop service. It is not connected to a running product.
Has anyone sen something like this.
First thing that I would check is to make sure the MAC address of your server is the same MAC address in the license file. You stated it was working and now its not.
@TravisNave Good point.. Didn't see that until you pointed it out..
Mark Lancaster
& Autodesk Services MarketPlace Provider
Changed it where? In the license file or at the server level? If at the license file you can't do that. You have to generate a new one.
Mark Lancaster
the MAC address has to match in the license file and on the server where LM tools is installed
one of these doesn't match
DarrenP
Basically, everyone is correct (@Mark.Lancaster, @TravisNave, @DarrenP), your license manager configuration is not configured correctly and you need a new license file.
Configuration for the license manager:
The paths should be local to the license manager utility tools.
Next, If you open the license file with notepad, the first line should have something similar to:
SERVER NP-Render2 E4B3181BD61E
The server name can be changed if needed, but if the MAC Address differ then what's actively being used on the server, you'll need to request a new license file.
This is what everyone has stated thus far, just thought I would combine them into one post.
Last but not least, make sure you update the license manager to the latest version, by downloading it from HERE
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Thanks Darin.Green and the rest of the guys that commented. I had the problem as posted by Aldred.
Pointing everything to be local to the license manager utility tool (C:\Program Files\Autodesk\Autodesk Network License Manager) solved the issue.
