I got a problem with installing AutoCAD 2012.
When i try to instal AutoCAD 2012 i get an Internal error 2738.
I did a lot of things to let it work but nother worked.
I hope you guys can help me with it because i need to do things for school with AutoCAD 2012.
You need to post the installation log file provided in your failure summary screen or in your %TEMP% folder.
Do you already have any other versions of AutoCAD installed? Is your copy legal?
And you downloaded it from the student site? AutoCAD 2012 should be expired for students by now in favor of 2013. Are you trying to install on Windows 8?
Make sure you do not have an AutoCAD 2012 folder already in C:\Program Files\Autodesk.
Even if you get it installed, I doubt you will be able to license 2012 if you have applied for 2013. The student program licensing is not permanent.
