Installation & Licensing
255 Views, 3 Replies
Installation problem
 I am finding difficulty in installation Autocad 2016, it is showing error1606. please advise
3 REPLIES 3
Otto
Hello itsmesadiqpasha and welcome to the Autodesk community!
It looks like you're seeing Error 1606 while trying to install an Autodesk product. This issue occurs because the installer tries to place files into another user's profile where you do not have write access. The following article(s) should help you resolve the problem:
"Error 1606: Could not access network location" when using "Run as" option to install
Get Your Autodesk Software Up & Running
Errors during AutoCAD software installation
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Hopefully the auto-response has helped you..  If not please see the verbiage under the line and follow the information to install your application.
Mark Lancaster
TravisNave
Do you have the ignore option for the 1606?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
