I'm trying to generate a new license file becuase we are retiring the box the current license file sites on. After going to their registration site and logging in it says my serial number isn't valid. Well I beg to differ with the infinite wisdom that is Autodek automation. That is the EXACT serial number that is printed on teh box of Maya 2013. I hate that they don't have any phone numbers to call them and everything gets redireted to a community forum when I really need to talk to a tech support agent. I managed to find an education support form and filled it out but i don't want to WAIT FOR TWO DAYS for a reply. I want this fixed NOW as I'm trying to complete a system build and distribute it.
Hi Jeff
Can you let me know whether you are still working on this?
Regards
David
Hi Jeff
Regards
David
It failed on the base image library for the material library. My suggestion this time is just run all the library installers manually as well. You'll see some folders in C:\Autodesk\AutoCADLT_2015_SWL_English_Win_64bi
Install Autodesk Material Library 2015 - Base Image Library Failed Installation aborted, Result=1622
Hi Jeff
These installed ok manually. However fails when I try to install. Log attached
Hi Jeff
Error 1622 is a problem writing to a temporary location. You probably need to completely clean out your %TEMP% folder and make sure you have full write access to that folder. You should be installing with admin rights, UAC off, and anti-virus temporarily disabled.
Try again and see if you get a failure.
Hi
Still fails i'm afraid.
Confirm
Regards
David
Hi
Confirm
Regards
David
Is anyone working on this? What is the next step?
I can't really think of anything else to try. It might be time to conisder an OS wipe and re-install.
You might try creating a new User with Administrative rights, log on as this new user then try installing AutoCAD LT as that user.
Danny
Danny
