Installation & Licensing
I can not any longer submit a support case???
5 REPLIES 5
mdhutchinson
491 Views, 5 Replies
Don't know if this is the beet place for this... but since I cannot post a support case.. it was the best option.
For some reason I cannot any longer submit a support case on our Subscription web site. After clicking on 'Select a Case Type' the 'Progressing..' spinning wheel runs without interuption and never finishes.
I had Imaginit log a support case for me... but have not heard anything yet.
Is anyone else seeing this... issue with this relatively new interface?
ooh.... I might have gotten a support case posted... but then again maybe not.
See the attached images.
ooh... I have Internet Explorer 9
5 REPLIES 5
pendean
in reply to: mdhutchinson
It's been stalling here since Wednesday too.
TravisNave
So, what do you actually need support with?  The community might be able to assist.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
mdhutchinson
in reply to: TravisNave
I am gearing up for 2014 rollout... I've built deployments and have successfully eliminated Autodesk 360 via manual ini file edits... I am now wondering how to go about eliminating Autodesk Sync. Is't Autodesk Sync part of Autodesk 360? And what is Content Service?  Of what use is it?
DarrenP
yes autodesk sync is autodesk 360 if you removed adsync from the setup.ini it will not install autodesk 360
i can't answer the what is content service question
DarrenP
dgorsman
in reply to: DarrenP
Content service is a search tool which runs as a service outside of AutoCAD, building an index for specified locations.  That way, when you use the Content Service to search for text in a title block, or have a certain block insert, etc. it doesn't actually search the files (which can take some time) but looks it up in the index system.
If you are a sole-user without any grunts/assistants to handle simple tasks it might serve some use, but a well organized file system will render most of its advantages moot.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Administrator Productivity
