How to change or reset licensing for 2020 relase Autodesk software
lukasz.badowski
lukasz.badowski
My question is how to change licensing type for 2020 relase if the Autodesk software does not start?
In previous version, working method from this link:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-change-or-reset-l...
In 2020 relase products, folder C:\ProgramData\Autodesk\CLM\LGS\ is not created.
Łukasz
Accepted solutions (3)
Replies (24)
mdavis22569
same link he gave ....
@lukasz.badowski  you're the 2nd person I've seen mention this ...
Are you getting the Licensing Manager improperly installed?
Mike Davis
Well, he didn't provide any details, so I assumed his license is sign-in based and he skipped the part where he's asked to delete the LoginState.xml file. That's the only reason I can think of why the LGS.data file would not be created.
We'll probably be able to provide more assistance once we get more information.
lukasz.badowski
I used network license an it work's fine but now license server is shut down and I want use single user license. When I start AutoCAD I receive FlexNet License Finder window (this is obvious becuse license server not working) and I can not click any icon from AutoCAD so I can not change license type. See screenshot.
Łukasz
Tony_Michniewicz
This process is covered in the Change License Method section of this page.  The example covers changing the license method for AutoCAD 2020 to a user license.  Another option is to replace the USER reference after -lm to "", which will set the license method to none.  In this case, you'll see the Let's Get Started dialog when you launch the next session of AutoCAD and you can select the desired license option there.
Hope that helps!
Tony Michniewicz
Revit Software QA Analyst
TravisNave
Because I love you guys, here's the way reset the licensing back to factory:
Open an elevated command prompt and enter this:
"%CommonProgramFiles(x86)%\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe" change --prod_key 001L1 --prod_ver 2020.0.0.F --lic_method "" --lic_server_type "" --lic_servers ""
Just copy/paste that into your CMD prompt and hit enter.  There should be no result.  But when you launch AutoCAD, it will ask for your license type.
Note:  Just change the product key and product version for other 2020 products.  To find the products installed, just use the same command with the list switch.
AdskLicensingInstHelper.exe list
Good Luck!
Autodesk Forums:
lukasz.badowski
@Tony_Michniewicz  and @TravisNave Thank You for help!
mdavis22569
Good Luck!
Can you give me a message about the list .... not getting it to work
Mike Davis
tobias_wiesendanger
Try it like this:
"C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe" list output>C:\temp\list.txt
It creates a file in a folder temp. After that you probably need a json pretty printer to read it.
sorry didn't work
natasha.l
Hello @Anonymous,
Please let us know what you are experiencing, please provide an error message or screenshot, if that's not available please let us know step by step what happened.
Thanks.
Hello
I face the same issue with Revit 2020. Tried all described way but i can't manage. Can't Autodesk provide an easier tool. I think i will simply uninstall and reinstall Revit that would be less brain consuming.
Daniel
tobias_wiesendanger
Try putting this comman in a cmd window. It should reset Revit. After restarting it should ask you what license type you want to use.
"C:\Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\helper\AdskLicensingInstHelper.exe" change --prod_key 829N1 --prod_ver 2022.0.0.F --lic_method ""
Thanks for helping but doesn't work. I will reinstall Revit that will be easier
tobias_wiesendanger
Thats up to you. I do this daily with a tool. The tool does a bit more like stopping a service and closing AdSSO.exe, which sometimes prevents the command from working. Revit of course has to be closed, but you probably knew that.
regards
Tobias
A tool is exactly what Autodesk should provide. I tried many ways but impossible, there might be also a security admin policy that blocks me.
Thanks anyway for your help.
tobias_wiesendanger
If you want to you can try mine:
https://github.com/TWiesendanger/ADSKLincensingModify
regards
Tobias
Thanks a lot. I will try later cause now i have to render a 3DS Max animation, might take 6 hours 🙂 Your tool seems to want to work because he tells he can't stop adsso.exe.
Long time i didn't work with Man & Machine. New the company in France in 1999.
Fantastic tool, Tobias you should sell it to Autodesk 🙂
Thanks a lot
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
